tonyrey46
Message 1 of 5
Hub 3
My Hub 2 was replaced two months ago due to countless drop outs. The Hub 3 performs much better but even so on two occasions the router dropped out all my devices and when I investigted the router had stopped broadcasting my SSID, the white light on the front was on and there were no other error/light indications
Switching the router power off/on fixes the problem but has any body else had similar problems. The Router firmware is 9.1.116T
Helpful Answers
  • 9.38K
  • 312
  • 1.01K
Message 2 of 5
Re: Hub 3
Hello tonyrey
Welcome to our forum, I am sorry you are having problems with the wireless it can be most frustrating. I notice that your firmware has been updated to 9.1.116V, how has it been performing recently?
Thank you
Nicola
Virgin Media Forum Team
All Replies
  • 9.38K
  • 312
  • 1.01K
Message 2 of 5
Re: Hub 3
Hello tonyrey
Thank you
Nicola
tonyrey46
Message 3 of 5
Re: Hub 3
Thank you for your post the hub has been ok for the last ten days, but I am keeping a log
  • 9.38K
  • 312
  • 1.01K
Message 4 of 5
Re: Hub 3
Hello tonyrey46
Thanks for getting back, I am pleased it seems to be performing a bit better, not sure if you are aware or not but the hub itself has a log as well, to access open a browser, navigate to 192.168.0.1 just click on "> check router status" in the middle of the screen.
Anyway fingers crossed it behaves for you.
Thank you
Nicola
Vizionz
Message 5 of 5
Re: Hub 3
Compared to the Superhub 2 ... SH3 is rubbish!
What Virgin don't tell you is that they have changed manufacturers and SH3 does not support Casting and is constantly dropping wireless signal.  I have connected a Netgear 48 into the SH3 as primary wireless router and not one of our 25 devices drops signal anymore!
