  • 24
DeanH67
Hub 3 upgrade
We upgraded our package last week and also had the Superhub 3 installed which is a massive improvement over the Hub 2 we had previously, however we still receive very poor WIFI signal upstairs in our house, any suggestions what we can do to improve it.
  • 16.47K
  • 1.37K
  • 3.36K
Re: Hub 3 upgrade
Depends on how thick the ceiling is, you could look at getting a pair of devlo home plugs with WiFi or possible running a Ethernet cable up stairs, and attach a wireless access point
  • 24
DeanH67
Re: Hub 3 upgrade
we had the TP Link WIFI extender before the Hub 3 was intalled, Virgin use Netgear powerline adapters and I can't get the TP link extender to work with them.
