chilly4756
Message 1 of 7
Hub 3 now no wifi on laptop
Hi all,
I have just swapped over to hub3, followed set up all working ok except laptop will not connect to internet. I made call to VM who talked me through various fixes, because another laptop I tried worked ok, he said it was my laptop at fault. I had been using the laptop 15 minutes before the hub 3 was delivered. he suggested taking my laptop to computer repair, he said it could be a driver problem. my computer is about 2 years old and windows 10. any ideas please.
  • 8.62K
  • 438
  • 1.02K
jb66
Message 2 of 7
Re: Hub 3 now no wifi on laptop
Sounds like your wifi drivers are out of date, have you tried updating them, your laptop should work with ethernet
chilly4756
Message 3 of 7
Thanks Legend.
I will go on google to find out what drivers I need and how to download them.
the person from VM also suggested buying a usb wifi dongle,
i was using my laptop 15 minutes before hub3 was delivered without any problems.
thanks for your reply
  • 9.65K
  • 672
  • 1.87K
Message 4 of 7
are the technical expertise of offshore - drivers maybe but i doubt it - broken certainly not - how is the wifi set up on the laptop - check it is not still trying to connect to the old hub - go to the wifi settings and forget the old networks you had? setup and start again with the ssid and passphrase on the hub3
____________________
Tony
chilly4756
Message 5 of 7
Hi Tony
thanks for your quick response, I went through that procedure with tech expert, but because another laptop connected ok, he said it could be the drivers
on my laptop, although it was working ok 15 minutes before delivery and connection of hub 3.
I have connected temp using Ethernet cable.
thanks
John C
  • 9.65K
  • 672
  • 1.87K
Message 6 of 7
chilly4756 wrote:
Hi Tony
thanks
John C
a tech expert and offshore if thats where it was is an oxymoron - drivers it may be but but in my mind its a long shot - always happy to be wrong - you could delete the drivers by uninstalling the wifi network card and letting win 10 find it again - the ethernet connection should then download drivers - see if that helps
what laptop is it and what wifi card does it have
Tony
chilly4756
Message 7 of 7
Tony and Legend
just to say a big thanks for all your help,
I used temp Ethernet cable, tried to download driver updates.
redone passwords, now all working on wireless.
thanks again for your assistance.
