survivor118
Message 1 of 7
Hub 3 WPS not connecting
Hi.
I recently was sent out a hub 3 to replace my hub 2. Previosuly with the hub 2 i have had no issues connecting wifi and with WPS button.
But now since having this, the 2 devices that i used to connect via WPS are not connecting... i.e. my Sky Q box and my Canon MG3150 wireless printer.
Does anyone know of if there is a issue with the WPS button and how to resolve it, as it is blocking connection to these devices.
My sky is ok has it is connected via ethernet, but my wireless printer is not "wireless" as i am having to use a printer cable to print.
any help would be great
Dal
  • 10.98K
  • 323
  • 669
Message 2 of 7
Re: Hub 3 WPS not connecting
Hey Dal,
Thanks for posting and welcome to the community Smiley Very Happy
Sorry to hear that you're having difficulties with your WPS connections. I've always found the best way to use WPS is from the Hub settings. If you go to 192.168.0.1 and then sign in using the details on your Hub, then go to Advanced settings, then wireless and then WPS. From there you will be able to connect via the push button or pin.
Can you please let me know if this helps.
Take care.
Heather_J
survivor118
Message 3 of 7
Actually got it sorted. I read another forum somewhere and someone on there suggested turning the router off then on again. What seems to happen is that after a while if you haven't used wps button, once pressed to connect, it tries to connect to the neighbours hub or system dependent on where thier hub/router is.
Anyways I thought I would try it and yes it worked.
bcj19
Message 4 of 7
I am having the same problem connecting my new hub 3 and had no issues with my previous hub connecting. I have like logged on to the site you suggested but it  Is not accepting my password which I have tried several times. I have also rebooted the router.
  • 6.86K
  • 182
  • 453
Message 5 of 7
Sorry to hear about this bcj19,
I've located your details and I'm unable to detect any cause for this at the moment.
Have you managed to get this sorted since posting?
Nat_J
ashetree
Message 6 of 7
Dear Heather_J,
I received a new Hub 3.0 in December.  In spite of all efforts my HP printer will not work.  If I manage to connect it as you suggest, it will print once, and then drops out.  According to the printer it is connected, it is shown in the connected devices in the router, it just doesn't work.  When I try to print, the printer "is not connected".  It was working perfectly on Hub 2.0.
Best wishes,
Ashetree
  • 10.98K
  • 323
  • 669
Message 7 of 7
Hi Ashetree,
Thanks for joining the thread and sorry to hear about the problems you're having. Have you ensured that your printer software is up to date? It might be an incompatibility issue. Do all other devices connect and perform well?
Talk soon,
Take care.
Heather_J
