  • 10
mermaids
Message 1 of 14
Hub 3 LAN port dropping in ROUTER mode
I have had the HUB 3 for a number of weeks now and from day one connected ethernet LAN port devices have suffered repeated frequent intermittent dropouts most noticeable when streaming video content, users suffer pixilation and a freezing picture. I have validated ethernet cabling, data socket outlets and to date have been baffled and frustrated as to the causation but noted that other users have reported similar symptoms albeit with the device in modem mode.
Resetting the HUB has made no difference to the symptoms described.
Hardware connected to the HUB are Apple devices, 2 x iMac and 1 x MacBook Air. Previous IP provider was Sky for which we had none of the described symptoms.
I am in possession of my old virgin HUB 2 and wondered if this an easy way to identify the HUB3 as having a fault - appreciate that I would have to contact Virgin Technical for them to reinstate my HUB2. Any help would be appreciated.
  • 9.37K
  • 362
  • 2.31K
Message 2 of 14
Re: Hub 3 LAN port dropping in ROUTER mode
You could try the Superhub 2, but that would just be playing a guessing game..
Better to copy-and-paste (or preferably provide screenshots of) the Hub 3's downstream, upstream and network log stats from the router status page. (Without logging in) it's found here: http://192.168.0.1/
I need the full network log.
Your problem will be unrelated to the modem mode port-flapping issue, as you're running in router mode.
You may be experiencing a DHCP issue I've seen before in router mode IF you experience the drop-outs every 54 minutes exactly, or it could be one of several other issues which the stats will show.
  • 10
mermaids
Message 3 of 14
This page displays information on the status of the Hub 3.0 HFC and IP network connectivity.
Status
Downstream
Upstream
Configuration
Network log
Refresh data
Date And Time Error Number Event Description
1970-01-01 00:00:31.00 68000500 TFTP failed - Request sent - No Response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:00:33.00 68001101 TFTP Request Retries exceeded, CM unable to register
1970-01-01 00:03:38.00 68000401 ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:00:31.00 68001101 TFTP Request Retries exceeded, CM unable to register
1970-01-01 00:02:57.00 82000200 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-11-02 14:27:04.00 68010100 DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-11-02 17:41:46.00 82000200 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-11-03 06:08:23.00 68010100 DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-11-03 10:41:14.00 82000200 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-11-03 13:59:02.00 68010100 DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-11-03 21:49:44.00 68010400 DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-11-04 07:00:59.00 82000200 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-11-06 22:24:41.00 68010100 DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-11-07 04:30:53.00 82000200 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-11-07 08:18:32.00 68010100 DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-11-07 17:02:15.00 82000200 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-11-07 17:35:16.00 68010100 DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-11-07 18:12:27.00 68010400 DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-11-07 20:10:05.00 82000200 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 10
mermaids
Message 4 of 14
having issues copying and pasting the router status page - will persevere
  • 10
mermaids
Message 5 of 14
Sorry rather embarrassing but copying and pasting, screenshot etc from iOS 10.8 does not work for me on this forum.mmmm Can you suggest another way? Have saved the information in word and preview which I could mail? Thanks
  • 10
mermaids
Message 6 of 14
[MOD EDIT: Inappropriate Images removed (Contains MAC address), please review the Forum Guidelines]
  • 9.37K
  • 362
  • 2.31K
Message 7 of 14
Either upload the power level images (no MAC address required) to your forum profile http://community.virginmedia.com/t5/user/viewprofilepage/user-id/337596 if you can or to a free image site such as http://imgur.com/
Then post the links to the images/gallery in this thread.
  • 10
mermaids
Message 8 of 14
Operational Configuration
General Configuration Value
Network access
Enabled
Maximum Number of CPEs
1
Baseline Privacy
Enabled
Docsis Mode
Docsis30
Config file
Va8201799de4e3b26.cm
SFID 697282
Max Traffic Rate 57600000
Primary Upstream Service Flow
SFID 697281
Max Traffic Rate 3250000
  • 10
mermaids
Message 9 of 14
Channel Frequency(Hz) Power
(dBmV) SNR
(dB) Modulation Channel ID
1 322750000 8.1 38.9 256 qam 20
2 314750000 8.5 38.6 256 qam 19
3 306750000 8.5 38.6 256 qam 18
4 298750000 8.4 38.6 256 qam 17
5 290750000 8.4 38.6 256 qam 16
6 282750000 8.3 38.6 256 qam 15
7 274750000 7.9 38.6 256 qam 14
8 266750000 7.9 38.6 256 qam 13
9 258750000 7.9 38.6 256 qam 12
10 250750000 8.1 38.6 256 qam 11
11 242750000 8.5 38.6 256 qam 10
12 234750000 8.6 38.6 256 qam 9
13 226750000 8.6 37.6 256 qam 8
14 218750000 9 38.6 256 qam 7
15 210750000 8.9 38.6 256 qam 6
16 202750000 9 38.6 256 qam 5
17 194750000 8.9 38.6 256 qam 4
18 186750000 8.8 38.6 256 qam 3
19 178750000 8.9 38.9 256 qam 2
20 170750000 8.9 38.9 256 qam 1
Channel ID Frequency(Hz) Mode Power
4 25800000 ATDMA 40 16 qam 6400000 5120
3 32600000 ATDMA 40 16 qam 6400000 5120
  • 10
mermaids
Message 10 of 14
Cable Modem Status
Item Status Comments
Acquired Downstream Channel(Hz)
322750000
Locked
Ranged Upstream Channel(Hz)
25800000
Locked
Provisioning State
Online
