Vorco
Hub 3.0
Can I upgrade my ok'd super hub to a new Hub 3.0 which I believe runs at 802.11ac transfer speed?
  • 1.14K
  • 29
  • 102
RedGooner
Knows their stuff
Re: Hub 3.0
Put your current hub into Modem Mode, and add your own router. All the latest ones have AC wifi spec.
Red (VM SH2 AC Beta tester)
Running on 200Mb VM service with SH2 AC in Modem Mode, with a ASUS RT-N66U router. With this setup I get Fantastic WIRED and WIRELESS Signals in my home. I dont work for VM. But I work in IT, and I know my tech.
My advice is at your own risk.
  • 120
  • 35
bambamboyo
Up to speed
Re: Hub 3.0
You will also gain issues with latency due to a fault with the new hub 3, see link below.
http://community.virginmedia.com/t5/Gaming-Support/Hub-3-Compal-CH7465-LG-TG2492LG-amp-CGNV4-Latency...
So if you are a gamer you will probably have issues and would be better sticking with SH2 or whatever you have now
Vorco
Re: Hub 3.0
Thanks guys for your repsposes, I appreciate what you say and shall stick with my super hub!
