  • 10
tank2521
Hub 3.0 separate channels?
Does anyone know of a way to set up the hub so I can select connecting to the 2.4ghz or 5ghz channel independently rather than just the one connection that switches between?
Helpful Answers
  • 11.06K
  • 1.02K
  • 2.25K
Re: Hub 3.0 separate channels?
You can make the changes by logging in to the Hub 3.0 at 192.168.0.1 and then navigating to Advance Settings, then Wireless, then Security.
All Replies
  • 11.06K
  • 1.02K
  • 2.25K
  • 10
tank2521
Perfect, thanks!
Didn't realise it was that simple
