  • 10
ranmanh
Hub 3.0 issue with DHCP Reserved list
I got a brand new Hub 3.0 and I have added 1 item from the DHCP lease table to the Reserved list in but I cannot delete it .
It does not matter if I check on the delete check box and apply changes, it refreshes and the item comes up again.
Any idea?
 thanks!
  • 9.42K
  • 313
  • 1.01K
Re: Hub 3.0 issue with DHCP Reserved list
Hello ranmanh
Sorry you were having problems with the hub 3 interface. I have just tried it on our test one with safari and it seems to be working, it was the same firmware level as yours by the way. If it is still happening it may be worth trying a factory reset of the hub Resetting your Virgin Media router
Thank you
Nicola
Virgin Media Forum Team
nielarcher
I'm having the same issue with the latest firmware version as of 28/07/2017 (9.1.116V).
I do not want to reset the whole modem to defaults as I've invested a considerable amount of time into configuring a while bunch of devices in DHCP, filters, etc. I'd like to see the software do what it is supposed to do.
This isn't the only feature broken on this page. The radio buttons for the currently registered list are supposed to put the correct details into the Add reserved section. Yet for most of them they put in the wrong MAC address (from one of the other entries) in.
  • 10
DuncanH
I have the same problem. Also mac filtering for time period doesn't work.
Hub 3.0v software is rubbish, only fix seems to be to buy own router but why should I for features I've been using for years on other modems/routers. We pay enough for virgin services !!!!!
