cs9896
Hub 3.0 internet on wifi drops out frequently but wired is fine
I have a hub 3.0, and this week I've noticed that my internet keeps dropping out when connected through wifi.
  • Wired is absolutely fine - every time
  • My wifi isn't broken on my computer - it works fine on my neighbour's router, or tethered to my phone.
  • Resetting the router doesn't do anything
When I connect by wifi, it works for about 2 mins and then drops out.
I would say it sounds like a buffer overrun issue on the wifi. Can someone take a look and let me know. Failing this I will consider requesting a new router
thanks
  • 7.59K
  • 188
  • 443
Re: Hub 3.0 internet on wifi drops out frequently but wired is fine
Hi cs9896,
Welcome to the forums, I am sorry to see that you have been having trouble with your wireless connection.
I have taken a look and things seem to be ok from this side.
Try Getting the best WiFi Signal and let us know if this makes a difference. If not pop a post back here and we will take another look.
All the best
Emma
  • 266
  • 21
  • 22
greeniegirl
Fibre optic
Afternoon
I know it can be very frustrating, we all use wifi a lot these days. Your hub 3 has 2 frequencies 1 is 2.4ghz (better range/coverage)  the other is 5ghz (faster speed short range/ not every device is compatible.
Best advice is to log into your router settings, change the wifi names so you can tell both the frequencies apart.  You can also change your wifi channel as you could be picking up interference.
Personally I would connect my devices to the 2.4ghz first for a while to see how you get on then make a decision upon which frequency works best for you.
Hope this helps
Goodluck
I am a virginmedia employee but all opinions are my own.
  • 5
Aaronix
Seems to be many other threads complaining of this issue. I simply don't believe that is a coincidence and I am very suspicious about Virgin's explanations which always place the problem squarely on the individuals reporting the issue I.e. it's a microwave, it's the room your in, it's a neighbours hive heating controller etc.
They need to look into this and find out what's happening and why, in my opinion.
The remote reset seems to sometimes resolve the issue for a few hours days.
