Thedubzy
Message 1 of 5
Hub 3.0 flashing white light
So the power went out when it came back on it looked normal but then the base light started to flash white and none of our devices can connect not even ethernet I tried on many phones and computers it don't even pop on the list any way it flashes white for a while then stops flashes white again go white then for a second green then red and starts over again
  • 72
  • 5
Thomask556
Dialled in
Message 2 of 5
Re: Hub 3.0 flashing white light
reset located on back of hub give that a go
Thedubzy
Message 3 of 5
Tried that all ready went back to the same problem
  • 72
  • 5
Thomask556
Dialled in
Message 4 of 5
90secs for hub 3 to reset if under 90secs it will just reboot sorry forgetting to mention
  • 3.88K
  • 121
  • 203
Forum Team (Retired) Adam_L
Message 5 of 5
Hi Thedubzy,
Thanks for the post! I am sorry to hear about your issues with your Hub 3's white light flashing with no internet, I apologise for any troubles incurred.
I have tried to test your connection from here but I was unable to locate any of your details via your forum account, in order to proceed with diagnostics I will need some more information. I will send you a PM (purple envelope at the top) detailing what's required in order to proceed with diagnostics.
Please respond to me there and I'll get this sorted for you.
Take care,
Adam.
