  • 5
tom1231
Message 1 of 8
Hub 3.0 WIFI set up
Hi Guys
Finally took delivery of said HUB 3.0, but have only been able to connect to internet via ethernet.
I have found the little booklets 'not a great help', and am wondering if somebody can give me advice, and/or point me in the right direction. No suggestion of any faults, but more of a lack of instructions for my set up.
I guess it would help if I add that I have an Old PC, running on Windows 7.
Not massively bothered about WIFI for the PC, but would LOVE to be able to use it for Internet Radio on my HIFI downstairs ( again, advice appreciated on this specific also....
Thank you for reading
  • 16.47K
  • 1.37K
  • 3.36K
Message 2 of 8
Re: Hub 3.0 WIFI set up
hiya @tom1231 what happens when you try and use the wifi?, any error messages etc.. since the wifi details are on the sticker on the hub, on some older devices you need to alter the wifi splitting apart the 2.4ghz and 5ghz into different networks, to do this if using the wired connection log into the hub via http://192.168.0.1 login password on the hub.. goto wireless settings and give the 2.4ghz and 5ghz a different name could just add 2.4 5 to the end of each apply/save and see how it goes.
  • 5
tom1231
Message 3 of 8
hi Paul,
thank you for your time..
Please bear with me on this:
Via 'Network and Internet'>'set up a new connection or network>set up a network('choose the wireless router or access point you want to configure')~this just shows a blank box with no info:does say that it might take'up to 90 seconds for unconfigured devices to appear'... so far nothing
Treis searching for'wireless manager'on my PC~nothing
  • 16.47K
  • 1.37K
  • 3.36K
Message 4 of 8
hiya, you shouldn't need to touch the new connection wizard.. so to check the PC has a wireless card?
  • 1.27K
  • 95
  • 235
stevedh2
Knows their stuff
Message 5 of 8
Wifi is usually enabled by default, and the wifi password is usually on a sticker under the hub.
What happens if you follow the instructions on your internet radio for connecting to wifi, does it find anything ?
  • 5
tom1231
Message 6 of 8
Paul,
Thank you for your reply.
My PC is OLD, about 10years now( imedia S1800)~doesnt have any such thing i dont think
I am running my access via Ethernet cable; am wondering if I disconnect it and then try for WIFI? ~ if I try now(through network settings)it says I am already online......
  • 5
tom1231
Message 7 of 8
Hi Steve
Thank you also for your input.
My HIFI just eventually says'no network'....
  • 5
tom1231
Message 8 of 8
Addendum:
Reading on a bit...do I need a wireless adapter/dongle...?
