VelNet
Hub 3.0 - Changing Settings Password
I seem to be unable to find an option in the control panel of the new Hub 3.0 that allows me to change the settings password.
Hope someone can help.
  • 3.02K
  • 385
  • 957
Re: Hub 3.0 - Changing Settings Password
Once you are logged in click, Admin and then Change password.
From the help page here:
https://help.virginmedia.com/system/templates/selfservice/vm/help/customer/locale/en-GB/portal/20030...
______________________
Scott
VelNet
I have already tried this, but it seems that when I click on Admin, I only have options for; Reload and Reboot, Remote Access and Info. Do you have any other suggestions?
  • 10.82K
  • 309
  • 632
Hi there VelNet,
Sorry to read you are having issues with changing the settings password for the Hub 3.0.
From what you have mentioned it seems that there is not an option for Change Password under Admin with the configuration page.
Have you tried a factory reset of the Hub to see if that function becomes available?
Let me know how you get on
Sam
dannyg
Just joined
i need to change my hub password because i think my downstairs is using my password i live in a flat
  • 329
  • 23
  • 84
KeithW
Fibre optic
Go here: http://192.168.0.1
Login and change your password
Hope this is of some help
All the voices in my head are my own voices - Find your own!
If I have helped you then please click on the "thumbs up" icon.
If you feel I have helped to solve your problem then please mark my message as a "Helpful Answer"
