Labuckis
How to go back to my old hub ?
I am using new hub 3.0 two computers is working fine but other two always have dropouts..
And why after reseting my new hub 3.0 I must wait so long? old one reseting in 2 min.
Please tell me how to connect my old hub
Thank you.
  • 16.5K
  • 1.38K
  • 3.37K
Re: How to go back to my old hub ?
hiya @Labuckis would involve call the activation team, and they should be able to reactive your old hub, if your on the 300mb wouldn't work on the older hubs, you can call them via 150 / 0345 454 1111
