  • 5
CaptCthulhu
Message 1 of 12
High packet loss making connection useless
Seemingly a common complaint among people that use virgin connections for gaming. I had been having a fine connection since I recently got my hub installed and had no complaints until now, having recently come back from holiday to a busted connection and a letter explaining how my bill is going up.
After much headscratching I've narrowed down the problem with the connection being packet loss and a quick google search shows up a lot of people that have had a lot of the same problems and the vast majority of them seem to have unsatisfactory results from any attempt to fix it, which doesn't give me much hope.
I've attached a tracert of a server I used to be able to connect to with no issues bar a little bit of delay (which is understandable as it's a server based in the United States) but now due to the packet loss it's 100% impossible to use my connection on that server.
It's not just limited to distant servers however, just far more noticeable.
  • 5
CaptCthulhu
Message 2 of 12
Re: High packet loss making connection useless
Here's a quick look at what my packet loss is looking like right now.
  • 10.98K
  • 238
  • 2.03K
Message 3 of 12
Welcome to the forum,
While we await an authoritative response from ForumTeam (5-9 days) then it might be useful to post some basics in meantime?:
  1. Your provisioned Tier (eg V200Gamer ?)
  2. The specific (Super)Hub (which I suspect is still a Hub3.0)
  3. Your approx location (redact last char on post code to comply with forum T&C's/Privacy) . eg I'm BN37N_  in Brighton but you appear to be provisioned on Thor6 CMTS which I suspect is way up North?
  4. Post Downstream,Upstream (not Burst Profile) stats and Network Log  which depending on actual Hub can typically be obtained via 192.168.0.1(RouterMode) - RouterStatus (no need to Sign in)  or 192.168.100.1 in ModemMode.
  5. Post another TBB/BQM as I wouldn't typically expect that Packet Loss via ICMP  even on SH3/Hub3/VMDG505 unless you had issues with your local power/signal levels (despite Puma6/Intel latency issue), or your cable segment/node was being currently upgraded with additional "channels". However running both 5min ICMP and TCPTrace from my end indicates  possible SNR/FEC issues on your cable segment.
Post again if you need further clarification or queries but little early to discuss "options/solutions" until we see your stats and/or ForumTeam have checked your status remotely!
Good luck
Regards Tony
"Life is a Binary Inspired Turing Computed Hologram"(don't PM or @Mention me - in case ignoring you offends)
  • 5
CaptCthulhu
Message 4 of 12
1. I currently pay for the rolling contract VIVID 200 broadband by itself.
2. It's a hub 3.0 that was installed a few months ago
Thanks for the response, if I need to post anything else just mention it.
  • 10.98K
  • 238
  • 2.03K
Message 5 of 12
CaptCthulhu wrote:
.....Thanks for the response, if I need to post anything else just mention it.
Thanks for confirmation, but you haven't yet posted ALL OF ITEM4 viz .   Downstream stats (I suspect you are/were still on 8/10 Downstream channels and they've now been increased to 16/20/24? ), Upstream and Network Log.
You'll have to select and screen print,scroll print each in turn or screen scrape etc
eg
We need complete info on ALL Downstream and Upstream channels and all ~20 records of the Network Log|
Regards Tony
  • 5
CaptCthulhu
Message 6 of 12
Hope this helps.
  • 5
CaptCthulhu
Message 7 of 12
  • 10.98K
  • 238
  • 2.03K
Message 8 of 12
OK I've got bored now waiting for the Network Log so as the Downstream is running hot and Upstream is a tad chilly then I suspect you're not on an optimal Tap (and possibly fairly close to Street Cab?). That should be obvious enough even for offshore Level1 to book you a Tech Visit - However......
It's possible that Networks may be "playing - aligning amp chain" or thermal compensation may drop(flakey) the level on colder day so the issue may heal up and/or the tech visit may be auto cancelled - so if they book a tech then ring up (as late as possible BUT) BEFORE you commit time off work/whatever to check if visit still pending. Forum Team will respond anyway (eventually) to make sure problem either fixed or to re-check your hub remotely and or any known Network issues/maintenance.
Good luck
Regards Tony
  • 15
  • 6
Md0h
Message 9 of 12
This seems to be a Glasgow wide issue, take a look at my BQM from G46.  Totally useless for anything that is latency sensitive. VOIP, gaming etc...
  • 10.98K
  • 238
  • 2.03K
Message 10 of 12
Md0h wrote:
This seems to be a Glasgow wide issue, take a look at my BQM from G46.  .....
If you can post your CMTS/HOST from the reverse DNS of your IP address (eg -THORnn-) then that could be helpful depending on topology of how various nodes/cable segments are configured.
Regards Tony
