PaulineDay50
Help with linking to router to my main superhub
I am trying to connect a to link router to my super hub to use as an extender
Helpful Answers
  • 1.28K
  • 96
  • 236
stevedh2
Knows their stuff
Re: Help with linking to router to my main superhub
what I assume you mean is you want to extend your wifi and create another access point.
1st connect the other router to the 1st with Ethernet cable (or power-line adaptor)
log onto the other router.
give it a static ip address that wont clash with anything
disable DCHP on it.
setup wifi, if you want to auto switch from the hubs, then give it the same ssid
make sure its on a different channel.
and that should be about it.
All Replies
  • 1.28K
  • 96
  • 236
stevedh2
Knows their stuff
disable DCHP on it.
