  • 6
Gmenzel
Help pls - SuperHub 3.0 keeps losing connections - error 84020200
hi,
called support 3 times on 3 different days and was given a date for an engineer to visit. Each visit was canceled "by the system" and i just called a 4th time to book the 4th visit - its next week wed.
Router keeps losing connections and i can see some errors in the log - see attached. I did check the coax and cable is fully seated and connected.
see attached.
I have had this now for the past 2 weeks and no resolution to date - hope that this way i get closer to the resolution.
[MOD EDIT: Inappropriate Image removed (Contains MAC address), please review the Forum Guidelines]
Helpful Answers
  • 9.13K
  • 302
  • 981
Re: Help pls - SuperHub 3.0 keeps losing connections - error 84020200
Hello Gmenzel
Welcome to our forum, I am sorry you were having problems with the connection and the frustration of the engineer being cancelled. We were having some intermittent problems in the area that may have caused your issues. Fortunately they are fixed now, your hub power levels
    0 dBmV        0.2 dBmV        0.2 dBmV        0.2 dBmV        -0.2 dBmV        -0.2 dBmV        0 dBmV        0 dBmV        0 dBmV        0 dBmV        0.2 dBmV        0.2 dBmV        0.2 dBmV        0.2 dBmV        0.2 dBmV        0.4 dBmV        0.5 dBmV        0.7 dBmV        0.9 dBmV        1.4 dBmV
and SNR levels
38.9 dB        38.6 dB        38.6 dB        38.6 dB        38.9 dB        38.6 dB        38.9 dB        38.9 dB        38.9 dB        38.6 dB        38.9 dB        38.9 dB        38.6 dB        38.9 dB        38.6 dB        40.3 dB        40.9 dB        40.3 dB        40.9 dB        40.3 dB
looking much healthier. Please bring us up to date.
Thank you
Nicola
Virgin Media Forum Team
All Replies
  • 6
Gmenzel
not seen any errors yesterday - however seen timeouts etc today again
  • 9.02K
  • 760
  • 1.88K
One of your downstreams is misbehaving, with low power and SNR.
The rest of the downstream stats and the network logs would be handy
A VM Forum Team member should pick up the thread in about a week and will be able to take a look. The engineer's visit is being cancelled by the system would suggest a known local segment fault.
  • 6
Gmenzel
hi,
sure. see here:
[MOD EDIT: Inappropriate Images removed (Contains IP addresses), please review the Forum Guidelines]
  • 9.13K
  • 302
  • 981
Hello Gmenzel
and SNR levels
Thank you
Nicola
  • 6
Gmenzel
Engineer has been last week and all looks ok now. Thanks for your help and support
