Leeann88
Green wifi light flashing continuously
Hi we have noticed on our router the wifi light is always flashing green. Been happening for a while now and I see from other questions it's not supposed to. Can you see if there is a problem with the line etc?
  • 20.53K
  • 542
  • 3.16K
Sephiroth
Re: Green wifi light flashing continuously
If you are having no WiFi access issues, then it's a known firmware minor issue. Some people have said that disabling WPS in the settings cures that. If you search on your topic you'll see plenty of correspondence, with hardly anybody actually having a WiFi problem.
