Leon51274
Green flashing light on hub
Hoping someone can help!
I have a green flashing signal light on my hub and every now and then some devices are losing signal, any chance you can check the line please to see if anything is not right? I've reset the hub several times with no success
Leon
  • 3.88K
  • 120
  • 203
Forum Team (Retired) Adam_L
Re: Green flashing light on hub
Hi Leon,
Thank you for getting in touch to let us know that your Hub has a green flashing light and some devices are losing signal. I apologise for any troubles incurred, I promise to do my best to help get this resolved for you.
I have tested your Hub and the wider connection from here and I can see that your Hubs logs show a number of T3 time outs across the upstream channels. I would like to get this investigated further by one of our engineers for you.
I will send you a PM (purple envelope at the top) detailing what's required to proceed with making the booking. Please respond to me there and I'll get this sorted for you.
Take care,
Adam.
