Badgerade
Frequent connection drops, 100mbps not 200mbps speeds seen
I'm getting fairly frequent connection drops out from Superhub.  (Wireless is fine - I'm in modem mode connected to my own router)
Frequent entries in the log show:
14-01-17 10:5382000200No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
14-01-17 10:5484000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
Just been on the phone to tech support who were not interested in the above errors, but did get me to reboot the router and run several speed tests, all of which were around the 100mbps area. (I should be on a 200mbps connection)
They also said there was an issue with the server and they would contact IT to fix it, and after that my problem should be fixed - this will take around 4-7 days.  Didn't sound very likely hence me posting this here Smiley Happy
For info:
Channel ID Frequency(Hz) Mode Power
1 46200000 ATDMA 42 64 qam 6400000 5120
4 25800000 ATDMA 42 16 qam 6400000 5120
3 32600000 ATDMA 42 32 qam 6400000 5120
2 39400000 ATDMA 42 32 qam 6400000 5120
Channel Frequency(Hz) Power
(dBmV) SNR
(dB) Modulation Channel ID
1 435000000 -3.5 36.6 256 qam 4
2 563000000 -8 36.3 256 qam 20
3 555000000 -7.2 36.6 256 qam 19
4 547000000 -6.2 36.6 256 qam 18
5 539000000 -6 37.6 256 qam 17
6 531000000 -6.2 36.6 256 qam 16
7 523000000 -6.2 36.6 256 qam 15
8 515000000 -6 37.3 256 qam 14
9 507000000 -5.5 37.3 256 qam 13
10 499000000 -5 37.6 256 qam 12
11 491000000 -4.7 37.3 256 qam 11
12 483000000 -4.7 37.6 256 qam 10
13 475000000 -4.5 37.6 256 qam 9
14 467000000 -4.4 37.3 256 qam 8
15 459000000 -4 37.3 256 qam 7
16 451000000 -3.7 37.3 256 qam 6
17 443000000 -3.5 37.3 256 qam 5
18 427000000 -3.5 37.6 256 qam 3
19 419000000 -3.4 37.3 256 qam 2
20 411000000 -2.7 37.3 256 qam 1
Can someone from Virgin please advise?  Not overly pleased about the lower speeds, but it's the connection drops causing the biggest issues.. Seems that kids can no longer function without internet access Smiley Very Happy
Thanks!
  • 3.88K
  • 121
  • 203
Forum Team (Retired) Adam_L
Re: Frequent connection drops, 100mbps not 200mbps speeds seen
Hi Badgerade,
Thanks for letting us know about your connection dropping, I apologise for any troubles incurred.
I have tested the connection from here for you and I can see that there's a lot of time outs inside the Hubs logs, an engineer will need to attend in order to  resolve this for you.
I will send you a PM (purple envelope at the top) detailing what's required in order to proceed with making the booking. Please respond to me there and I'll get this sorted for you.
Take care,
Adam.
Badgerade
I've replied to the PM but no response so far.. connection still seems fairly unstable.
  • 6.62K
  • 174
  • 438
Hi Badgerade,
Apologies for the delay in getting back to you.
I'm really sorry also for the connection issue experienced.
I've checked the network segment and this is currently clear of any issues, however, the equipment levels are out of spec.
I'd like to arrange for an engineer to investigate this further.
I've sent you a private message so that we can get this booked in.
Speak to you soon,
Nat_J
