phljrmn
Flashing Wifi light
Over the past few days, the wifi light on my Virgin Hub 3 has been flashing constantly.  Having visited the community for clues, I've followed every suggestion re fixing the problem i.e. restart, checking wiring, pressing the WPS button (this works for a short time) etc, but to no avail.  My internet and wireless appear to be OK although, my wireless performance does seem to dip from time to time (am I imagining this?). Bottom line is the constant blinking is annoying to say the least.  Does anyone have a definitive answer on how to fix this for good?
  • 11.01K
  • 324
  • 670
Re: Flashing Wifi light
Hi phljrmn,
Thanks for posting and a warm welcome to the Community Smiley Very Happy
Sorry for the flashing light, I know it can be frustrating. Everything looks good from our end and if you're not reporting any immediate fault, we can monitor this with you for a few weeks and see if it continues.
Take care.
Heather_J
phljrmn
Thanks for your reply Heather.  That's fine and I'll let you know if things change.  If it gets really annoying I can always stick a piece of black tape over it!
Phil
  • 1.82K
  • 28
  • 209
deans6571
Super solver
In actual fact, this is caused by a bug in the Hub 3 firmware.
I also get the green flashing wifi light occasionally even though the wifi actually works as normal! See this thread for how to stop it flashing:
http://community.virginmedia.com/t5/Networking-and-WiFi/Superhub-3-Green-Flashing-Wifi-icon/td-p/328...
Smiley Wink
__________________________________________________________
Twitter : @deans6571 / Xbox Live : Deans F
