JamBr92
Flashing WIFI Light
Hello,
My router has the WIFI light flashing to indicate that something is wrong but the Internet connection is fine. Not had a problem with connection at all since I got the router but the light has been flashing for 2 or so days.
Not really sure what the problem is, as I say, the connection is perfect.
Any ideas, thank you in advance.
Regards,
Jamie.
  • 6.24K
  • 233
  • 355
Re: Flashing WIFI Light
Hello JamBr92,
I have checked your connection and everything looks fine, if the light is still flashing on your hub try to reboot by the mains and let me know if there's any problems.
Thanks Smiley Happy
Rose
  • 20.77K
  • 557
  • 3.22K
Sephiroth
Please search the forum on the term FLASHING. The subject has been done to death and in the largest thread you'll find on the topic, it's all explained and how you can (sometimes) stop it.
