  • 8
NaheemM
Message 1 of 5
Extend my wireless connection using wps
I'd like to extend my wireless range, the super hub 3 on just on its own won't work
I have another wireless router which has wps feature. I don't know how to connect 2 router wirelessly using wps please guide me if it can be done.
  • 16.48K
  • 1.37K
  • 3.36K
Message 2 of 5
Re: Extend my wireless connection using wps
What's the make and model of the other router since I wouldn't advise linking the routers together since the wifi speed could get horrible, always best using wired between them.. If can't do wired could use a pair of home plugs
  • 8
NaheemM
Message 3 of 5
I have a sky router, I thought about wiring but it to much hassle and rewriting the home. The plugs it would do the job but I don't want to spend if it can be done for free using wps.
So plz let how it can be done
  • 8
NaheemM
Message 4 of 5
sky router SR102
  • 16.48K
  • 1.37K
  • 3.36K
Message 5 of 5
don't think you'll be able to link them together via wifi, aka making the sky router act as a repeater, since guess on the sky box will have there is own software/firmware.. you could flash It e.g. -> https://wiki.openwrt.org/toh/sky/sr102 but doing this wrong will turn the router into a brick.. this should possible give you the option of repeater mode.
