Jayeg1990
Ethernet ports not working
When new the Ethernet ports seem to work,a year on I have plugged in two different cables for TV and x box with no network or lights appearing. When restarting, port lights flash momentarily but then nothing when connected and no network is found on my TV or xbox.
Is this a hardware issue or can it be fixed in settings?
  • 10.82K
  • 308
  • 631
Re: Ethernet ports not working
Hi there Jayeg1990,
Sorry to read that the Ethernet ports on the Super Hub are not working.
Can you let me know if the following have been tried please?
Have you tried a factory reset of the router? If so did that make a difference at all?
If you plug one side of the Ethernet cable into say port 1 and the other side into port 3 (loop back test), do any lights come on?
Have you tried another Ethernet cable?
If you have tried these and the ports are still not working, I can arrange for a replacement router to be sent to you.
Let me know how you get on
Sam
Jayeg1990
Hi Sam
Yes got it sorted Ethernet cable was faulty checked all ports with loop back test all OK thank you for your help
Jaye
  • 10.82K
  • 308
  • 631
Hiya Jaye,
Thanks for the quick reply.
I'm glad you found out the cause and it is now working ok Smiley Happy
If there are any further issues by all means get back in touch.
Have a great Christmas and a happy New Year.
Take care
Sam
