  • 289
  • 8
  • 31
praxis
Superfast
Ethernet port
on the Superhub 2 is there a main primary port or are they all the same ?
  • 22.25K
  • 851
  • 3.23K
Re: Ethernet port
they are all the same
  • 11.12K
  • 1.03K
  • 2.26K
Re: Ethernet port
...except if you put it in Modem Mode, then only one Ethernet port is active to connect your router or single Ethernet device.
