RHA
Message 1 of 8
Ethernet cables
I'm currently setting up a let, with five student rooms on two floors. Is it desirable to have Ethernet cabling to each room? Thanks
Helpful Answers
  • 33
twin--turbo
Message 6 of 8
Re: Ethernet cables
There should be no contention on the switch. The broadband will be 200mbps asynchronous, max. Each port is 1000 full duplex with each port it's own collision domain.
Unless it's a very crappy switch it will be fine.
TT
All Replies
  • 1.27K
  • 95
  • 235
stevedh2
Knows their stuff
Message 2 of 8
Re: Ethernet cables
if its not too hard to do...well my daughter hated having to survive using wifi for a couple of days because she forgot to take an ethernet cable with her.
  • 20.73K
  • 554
  • 3.21K
Sephiroth
Message 3 of 8
Re: Ethernet cables
Absolutely! And, as the other poster has alluded, perhaps leave a cable or two in the room.  If you're gonna cable to the room, you'll prolly want a central switch close to the router so that you can actually distribute stuff.  However there + and - to consider.  The router will have 4 Ethernet ports.  You've got 5 rooms; one Ethernet port per room maximises throughput potential per room. Five cables from a switch, the switch connected to a single Ethernet port requires a switch that minimises contention when all 5 students are at it streaming.
So there's a bit of thinking to do.  You'll still find students who'll only be interested in wireless and might whinge when the Hub's woreless won't reachthrough a couple of floors and walls.  If you are going to be a dream landlord, you could install Powerline adapters on each floor to broadcast wireless.
Keep us posted on this adventure.
  • 1.32K
  • 86
  • 218
Knows their stuff
Message 4 of 8
Re: Ethernet cables
If you want to go the whole hog, I would put two Ethernet connections in each room and one wireless Access Point per floor, all wired back to a 16 port switch next to the router. You could also possibly turn off the wiresless on the router.
There are 10 types of people: those who understand binary and those who don't
  • 22.23K
  • 845
  • 3.23K
Message 5 of 8
Re: Ethernet cables
if you want since easy to manage wireless look at the Unifi. I been installing them for years. i now have over 20 in 3 buildings
  • 33
twin--turbo
Message 6 of 8
Re: Ethernet cables
TT
  • 20.73K
  • 554
  • 3.21K
Sephiroth
Message 7 of 8
Re: Ethernet cables
Exactly. Avoid a crappy switch and you'll minimise contention.
RHA
Message 8 of 8
Re: Ethernet cables
Thanks very much for the sensible responses guys. I'll discuss the options with the electrician tomorrow before he rewrites theplace.
Much appreciated!
