PantsMoustache
Does port forwarding just not work on the SuperHub 3.0?
I work in IT and have port forwarded my fair share of routers in the past.
It just doesn't work on the SuperHub 3.0, it worked fine on the 2AC.
Proof:
http://imgur.com/a/mVdbE
The DMZ also doesn't seem to work.
I have tried factory resetting the device to no avail. Any other ideas?
  • 13.63K
  • 719
  • 4.72K
Re: Does port forwarding just not work on the SuperHub 3.0?
Well I have a hub 3 and port forwarding does work - although it wouldn't let me forward one of my Teamspeak ports so I used the DMZ instead.
Proof
Success: I can see your service on 94.173.103.9 on port (80)
Your ISP is not blocking port 80
Your IP:
Port to Check:
________________________________________
Only use Helpful answer if your problems been solved.
