abs
Control4
Does any one know if the new Virgin V6 boxes work well with Control4 remotes?  thanks
  • 8.84K
  • 381
  • 621
Re: Control4
Hi abs,
Welcome to the Community!
I've not had much experience with the Control4 but I can see from the user guide that it uses IR, the same as the V6 box. I can't say for certain whether it will work or not, though.
Hopefully someone from the Community will be able to jump in and help out with this.
All the best! Smiley Very Happy
Josh
abs
Re: Control4
Thanks.  Did some research and should work.
