DrClogs
Constantly losing connection although wireless seems ok. Need to disconnect and reconnect.
How do I fix this problem?  It has plagued me and I have had no help from engineers.  I finally found that the IP address isn't assigned and have dchp errors.  Can anyone help?
  • 3.88K
  • 121
  • 203
Forum Team (Retired) Adam_L
Re: Constantly losing connection although wireless seems ok. Need to disconnect and reconnect.
Hi DrClogs,
Thanks for the post! I am sorry to hear about your issues with your connection constantly dropping. I apologise for any inconvenience caused.
I have tested the connection from here and I can see that your Hubs logs are showing a lot of time outs inside. I would like to arrange for this to be investigated further for you by one of our engineers.
I will send you a PM (purple envelope at the top) detailing what's required to proceed with making the booking, please respond to me there and I'll get this all booked and secured for you.
Take care,
Adam.
