Graham1983
Connection problems
How many times do I have to report this situation before someone at VM actually does something!!! For weeks now I have had issues with this... I have rang, emailed even logged a formal complaint and literally nothing has been done other than the usual "turn it off and on again" clearly there is something up with YOUR equipment!!!. Can you please arrange for someone to contact me and arrange an engineer to come out as I am convinced it is YOUR equipment that is the problem.
  • 8.32K
  • 358
  • 586
Re: Connection problems
Hi Graham1983,
Thanks for posting!
I'm really sorry to hear you've had trouble with your connection.
I've located your account and there's currently an unplanned network outage affecting your services - Ref.(F004999136). This issue is priority one so our technicians will be reviewing it later today.
I'll check back with you a little later on to see if the fault has cleared.
Speak soon Smiley Very Happy
Josh
