PictonUK
Message 1 of 7
Connection drop 30-60 second intervals
Hi, I've been having the same issue for quite some time now. Every so often the internet speed drops drastically for around 2-3 seconds at 30 second intervals. Normally this wouldn't be a problem but it makes online gaming impossible.
I've phoned the virgin call centre a number of times but all that is suggested is that I reset the router. This does solve the problem temporarily but as the issue keeps coming back it would be good to find a permanent solution.
I'm using a wired Ethernet cable to my main gaming PC.
Any help would be greatly appreciated.
Helpful Answers
  • 3.88K
  • 120
  • 203
Forum Team (Retired) Adam_L
Message 6 of 7
Re: Connection drop 30-60 second intervals
Hi PictonUK,
Thanks for letting us know about your issues with your connection dropping for 30 - 60 second intervals, I apologise for any inconvenience caused.
I have tried to test things from here, however I was unable to locate any of your details via your forum account. In order to proceed with diagnostics I will need some information from you.
I will send you a PM (purple envelope at the top) detailing what's required in order to proceed with diagnostics. Please respond to me there and I'll get this sorted for you.
Take care,
Adam.
  • 3.88K
  • 120
  • 203
Message 7 of 7
Hi Josh,
Thanks for responding to me!
I have now managed to run some tests from here and your Hub went offline whilst I was testing it, I would like to arrange for an engineer to attend and investigate things further for you.
I will send you another PM (Purple envelope at the top) detailing what's required in order to get an engineer booked in. Please respond to me there and I'll ensure this all gets booked and secured for you.
Take care,
Adam.
All Replies
  • 9.01K
  • 760
  • 1.88K
Message 2 of 7
Posting some basic diagnostic info may help.
Navigate to the hub's GUI using http://192.168.100.1
Don't log in, click the Router Status button in the top right of the screen.
Copy \ Paste the Downstream, Upstream, and Network Logs.
Don't worry about the formatting.
PictonUK
Message 3 of 7
Downstream
DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz) 299000000 Hz 251000000 Hz 259000000 Hz 267000000 Hz 275000000 Hz 283000000 Hz 291000000 Hz 307000000 Hz
Lock Status(QAM Lock/FEC Sync/MPEG Lock) Locked Locked Locked Locked Locked Locked Locked Locked
Channel ID 17 11 12 13 14 15 16 18
Modulation QAM256 QAM256 QAM256 QAM256 QAM256 QAM256 QAM256 QAM256
Symbol Rate (Msym/sec) 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000
Interleave Depth I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17
Power Level (dBmV) 20.8 dBmV 19.6 dBmV 19.5 dBmV 19.4 dBmV 19.0 dBmV 20.8 dBmV 20.8 dBmV 20.2 dBmV
RxMER (dB) 39.0 dB 39.4 dB 39.4 dB 39.4 dB 39.4 dB 39.4 dB 39.3 dB 38.6 dB
Upstream
US-1 US-2 US-3 US-4
Channel Type 2.0 2.0 N/A N/A
Channel ID 1 2 N/A N/A
Frequency (Hz) 37600000 Hz 31000000 Hz N/A N/A
Ranging Status Success Success N/A N/A
Modulation QAM64 QAM64 N/A N/A
Symbol Rate (Sym/sec) 5120000 5120000 N/A N/A
Mini-Slot Size 128 128 N/A N/A
Power Level (dBmV) 36.8 dBmV 36.3 dBmV N/A N/A
T1 Timeouts 0 0 N/A N/A
T2 Timeouts 0 0 N/A N/A
T3 Timeouts 0 0 N/A N/A
T4 Timeouts 0 0 N/A N/A
First Time Last Time Priority Error Number Description
22/10/2016 17:23:50 22/10/2016 17:23:50 Critical (3) 2436694078 TOD established
  • 9.01K
  • 760
  • 1.88K
Message 4 of 7
Your downstream power levels are way too high and need to be adjusted.
You will need to contact VM for resolution, either by waiting here about a week until a VM Forum Team Member picks up the thread, or give them a call on 150 from a VM line or 0345 454 1111 for a quicker response.
PictonUK
Message 5 of 7
Thanks for your help. I really appreciate it.
I'll make sure to contact VM right away.
  • 3.88K
  • 120
  • 203
Message 6 of 7
Hi PictonUK,
Take care,
Adam.
  • 3.88K
  • 120
  • 203
Message 7 of 7
Hi Josh,
Take care,
Adam.
