  • 28
scouse2
Connection drawing Ethernet
Can some kind soul draw me a simple line drawing showing the connection
From super HUB 3 to apple Time capsule and the new virgin V6 box (Ethernet) and the Internet and of course the computer
Helpful Answers
  • 16.48K
  • 1.37K
  • 3.36K
Re: Connection drawing Ethernet
so hub (Ethernet) --> V6 Tivo
(Ethernet) ---> PC
(Ethernet) ----> apple Time capsule
hub (coax) ---> Internet
All Replies
  • 16.48K
  • 1.37K
  • 3.36K
you could use e.g. https://www.draw.io/
  • 28
scouse2
Thank you but i think you missed the point i need a drawing to show what connects with what not how to create the drawing
  • 16.48K
  • 1.37K
  • 3.36K
(Ethernet) ---> PC
