colm123
Connecting tv without tivo
Just had install by technician and trying to connect my tv to the Hub3.0 via a cat 6 cable to the ehternet port on tv. Hub lights up on port but tv doesnt see a network. Checked for duff cable but same with two different cables.
Any help welcome.. thanks
Colm
Helpful Answers
  • 25
  • 12
dowie
Re: Connecting tv without tivo
If your TV is a smart tv you may need to go into the network settings and check that DHCP is enabled this should then enable the SH3 to assign the tv an IP address. If its not a smart tv it should be the same but the tv will only update its main firmware.
Dowie
All Replies
  • 25
  • 12
dowie
Dowie
  • 242
  • 15
  • 55
steelysteph
Superfast
Are other things connecting ok, whether by cable or wifi?
colm123
Thanks that worked a treat.
