Sabretiggr
Connecting to Superhub via LAN
I installed our new Hub3 today (our Hub2ac died completely over the weekend). I can connect via WiFi without a problem but our Lan connections are not working (laptop, tv Youview box, printer). They seem to be allocated an odd ip address (outside of the 192.168 range) and don't want to work even if I change those ip's.
Any ideas, please on what I need to do? Laptop is running Win 10, printer is an Epson.
Many thanks.
  • 1.27K
  • 94
  • 235
stevedh2
Knows their stuff
Re: Connecting to Superhub via LAN
Are they both connected directly to the Hub3 with 2 separate leads. If it had just been 1 connection then it might have pointed to a dodgy cable.
If they all go via a switch and a single cable to the Hub, then check that, and also try plugging laptop directly into Hub.
Anyway try different cables, try plugging into different ports and try rebooting the router. If all fails then looks like dodgy hub, I think someone else had a similar problem.
  • 13.14K
  • 375
  • 1.07K
Moderator
Moderator
Hi Sabretiggr,
I'd just like to add a factory reset of the Hub to stevedh2's list.
Keep us posted with how things go.
Ralph_R
Forum Moderator
Sabretiggr
Thank you both.
The laptop is connected direct via cable (not working, so now on WiFi instead). The printer is connected direct on a different port. The YouView box is connected via PowerLine, via a switch and a third port on the router.
I've managed to force the YouView box to work (manually entered all the IP details, and eventually it worked) so I'll have a go at doing the same again with the printer and laptop - the first time I tried with all the devices it failed.
