Trevor2910
Connecting my TV to my Wifi
I'm trying to reconnect my wifi (via my Virgin super hub). I'd connected before but for unknown reasons it's disconnected it's self. I get as far as it's asking to "select the security method of your router". I'm given the choice of None, WEP, WOA/WPA2-PSK(TKIP) or WPA/WPA2-PSK(AES). I can't which one I'm supposed to connect to please help. Thanks.
  • 16.46K
  • 1.37K
  • 3.36K
Re: Connecting my TV to my Wifi
i would be either WPA/WPA2-PSK(AES) / WOA/WPA2-PSK(TKIP)
