  • 9
will4jan
Message 1 of 12
Connecting mobile to home wifi
Recently my Virgin mobile has failed to connect to my Virgin wifi. More accurately, the connections are listed under Settings - Wifi on my mobile; I am required to enter the password and the screen shows that the mobile is "connecting" and then "connected" but the connection only lasts for a few seconds. Previously, the connection had been made automatically.
The wifi supports other devices so the Virgin Help Wifi team say it is not a Wifi problem. My mobile connects to other Wifi so the Virgin Help Mobile team say it is not a problem with the mobile.
I have spent hours on the phone including to the premium service but without resolution. I'm stuck and don't know what to try next. Could the fact that I'm short on storage space be an issue?
Helpful Answers
  • 12.48K
  • 353
  • 1.45K
Message 8 of 12
Re: Connecting mobile to home wifi
Hi will4jan,
Sorry about your Wi-Fi issues though glad to see you've been getting some good support from the Community Smiley Happy
Although it may not be related to your reported problem my tests reveal low modem SNR on the Hub. The network segment to which you connect has shown dipped channel SNR today, intermittently,  from about 3:30pm to 5pm. It seems to have abated now and no faults preceded this.
It's worth me keeping an eye on that just in case. But the low modem SNR needs attention from an engineer, so please reply to my PM (purple envelope icon, top right of page) and I'll schedule an appointment for you.
In the meantime please check out our help articles relating to WiFi:
If the issue persists following the engineer visit, and if the wireless configuration changes don't help, please post an update on here and I'll get back to you about this. I'll re-check the network segment in case that needs attention and consider replacing your Hub as a last resort.
Bye for now Smiley Happy
Jen
All Replies
  • 329
  • 23
  • 84
KeithW
Fibre optic
Message 2 of 12
Try resetting your superhub
Once you have done this use the WiFi settings/password on the bottom of your superhub.
All the voices in my head are my own voices - Find your own!
If I have helped you then please click on the "thumbs up" icon.
If you feel I have helped to solve your problem then please mark my message as a "Helpful Answer"
  • 9
will4jan
Message 3 of 12
Thanks. Already tried switching on and off, and resetting i.e. going back to factory settings.
  • 9.34K
  • 797
  • 1.96K
Message 4 of 12
Which Hub is it?
What phone are you trying to connect?
Are you using WPA2 with AES wireless encryption?
  • 9
will4jan
Message 5 of 12
It's a Super Hub 2 and my mobile is a Sony Experia M4. I don't know the answer to the third question - how do I find that out?
  • 9.34K
  • 797
  • 1.96K
Message 6 of 12
Open up the Hub's GUI using http://192.168.100.1
Sign in and click on the wireless icon and the Security Method will be listed for both the 2.4Ghz and 5Ghz networks, you can change method by clicking on the drop down menu remembering to save your changes.
Have you tried connecting to the 2.4Ghz and 5Ghz network, the phone should be able to connect to either.
  • 9
will4jan
Message 7 of 12
I've tried connecting to both 2.4 and 5 ghz services, with identical results. The security setting is WPA Auto. Thanks for pointing out that I could make changes to the router settings, I didn't know I could do that. I haven't changed anything yet although the Virgin folks remotely tried changing channel among other things.
  • 12.48K
  • 353
  • 1.45K
Message 8 of 12
Hi will4jan,
Jen
  • 9
will4jan
Message 9 of 12
Problem solved by the engineer installing a new hub. Apparently the problem is symptomatic of a hub beginning to reach its use-by date.
Jamoulden
Message 10 of 12
I am having the exact same problem with my virgin mobile not connecting to my virgin home wifi. It constantly cuts out and goes onto 3G even though I'm at home and should be on home network. It's using all my data even though I'm at home!
