Wardy3
Connecting a printer via an ethernet cable
Hi  i have just purchased a printer (epson wf2660)  and it can be connected via wireless/usb or ethernet cable.
Query - can it be connected directly to my superhub 2ac with an ethernet cable.?
And if it can, would it be a network printer usable by everyone on my wireless router?
Any advice would be greatly appriecated.
Peter
  • 9.34K
  • 797
  • 1.96K
Re: Connecting a printer via an ethernet cable
Yes, you can direct directly to the SH.
Yes you can set it up as a network printer so all devices can connect to if if the printer drivers are installed on the device.
Wardy3
Thanks for the info - will give it a go with my new printer cheers
  • 33
twin--turbo
The printer should get it's network IP address from the router, although it's usually better to FIX this by giving it a static IP address. The manual should explain this.
Once it's plugged in, install the epson software , if it's anything like most printers of the last 10 years the software will do all the discovery work of finding the printer.
