ppringlechiro
Connecting a D-Link 1520 WiFi range extender
I have a D-Link 1520 WiFi range extender that won't since with my router? - HELP!
  • 16.52K
  • 1.38K
  • 3.38K
Re: Connecting a D-Link 1520 WiFi range extender
hiya @ppringlechiro what happens when you try?, what hub do you have?, what lights are showing on the dlink.. how close is the dlink to the hub?
