JankyTheBob
Change Public IP Address on Superhub 3.0?
Is it possible?
I always like changing my IP address after a few months and would like to do so now. My last router just required that I turned it off for a few minutes and then turn it back on and I would have a new IP address.
This Superhub however isn't that simple (Sticky or Static IPs I am guessing) and was wondering if there is a way to do this.
  • 2.76K
  • 223
  • 842
Dave_cq
Trouble shooter
Re: Change Public IP Address on Superhub 3.0?
The VM WAN IP is very very sticky indeed.  You would need to leave your hub switched off for days to stand any chance at all and even then it might not change.  It will change once if you put it into Modem Mode and attach your own router to it.
********* SuperHub 2ac - Asus rt-ac68u Router - Vivid 100Mbps **********
Electron
  • 1.29K
  • 65
  • 235
Knows their stuff
I would assume it also depends on the number of Customers in a particular area.
I've been away on holidays in the past, for up to 3 weeks, and still got the same IP address......
  • 16.46K
  • 1.37K
  • 3.36K
why do you want a different IP address?, since the only way to make sure the IP address changes is putting the hub into modem mode, and attach a 3rd party router.
