  • 7
mydog2409
Cannot reset setting on Hub 3.0
Hello,
I have followed the instruction on the support site on how to reset the Hub 3.0, but it does not work for me. Is there any other option that I could use?
  • 253
  • 6
Big-Gaz
Up to speed
Re: Cannot reset setting on Hub 3.0
I had this issue and couldn't remember my password, so I phoned up tech support who reset it for me.
If you know the password to the admin area, I think you can reset it in there, but not 100% sure.
_____________________
Gaz
  • 7.36K
  • 314
  • 523
Hi mydog2409,
Thanks for posting!
Sorry to hear you're having trouble resetting the Hub 3.0.
Can you tell me what you've tried so far?
Look forward to hearing from you! Smiley Very Happy
Josh
