  • 17
cougarric
Can't connect wireless devices to superhub. Ethernet working fine though
My superhub seems have had some sort of malfunction today. Now all wireless devices won't connect to it.
I have reset it to factory settings and found I could access it fine. But when I set a new password it doesn't allow access, saying the password is incorrect.
Not sure where to go with this, as usually a reset solves everything.
  • 17
cougarric
Re: Can't connect wireless devices to superhub. Ethernet working fine though
Just to clarify, my wired connections are ok, it's just the wifi that's messed up.
  • 10.59K
  • 311
  • 653
Hey there cougarric,
Sorry to hear about the problems with your Hub. It sounds like your Hub is struggling if it's not allowing you to use personal settings.
Let's look into this further and replace it if needed. I'll drop you a PM (purple envelope, top right) so we can keep in touch.
Catch you soon,
Take care.
Heather_J
