keano1916
Can't connect wired devices
I repeatedly cannot connect devices via ethernet. I know that my ethernet cables are 100% fine and in working in order. i can connect every so often after rebooting and resetting my router but as soon as I turn off the device I cannot reconnect. It is becoming extremely annoying and I am seriously considering changing service provider. I have done some homework and it seems that this is quite a regular occurrence for VM hubs, has anyone else on here experienced this or have any advice? Cheers, Joe.
  • 10.82K
  • 309
  • 632
Re: Can't connect wired devices
Hi Joe,
Thanks for posting and a warm welcome to the community.
Apologies you are not able to connect wired devices to the network.
Do you get any error messages when trying to re-connect?
Does this happen on all ports of the router?
Let us know how you get on
Sam
keano1916
Hi Samantha,
No I don't get an error message just the device is not found and yes it happens on all ports.
Joe
  • 10.82K
  • 309
  • 632
Hi Joe,
Thanks for getting back to me with the information provided, I appreciate it.
In regards to this issue, I have sent you a PM (purple envelope icon, right corner) with some additional details.
Hope to hear from you soon
Sam
