Tarek866
Can't connect to wifi
We have a Hub 3.0 that is currently not connecting to the internet. The wifi light is green and base LED light is flashing green. It says I am connected but there is no wifi service. I've turned the box on and off and it still does the same thing. Help!!
0
  • 1.34K
  • 102
  • 247
stevedh2
Knows their stuff
Re: Can't connect to wifi
Have a read through this thread and see if anything anyone on there does helps
http://community.virginmedia.com/t5/Networking-and-wireless/Wifi-Light-Flashing-on-my-hub3/td-p/3010...
  • 4.34K
  • 91
  • 282
Moderator
Moderator
Hi Tarek866
Welcome to the community. I'm really sorry to hear of the loss of service you've experienced. Are you still experiencing any problems with the wifi connection? I'm unable to locate your account so I've sent you a PM(purple envelope, top right corner) for some additional info to help us look into this just in case you are still having any problems.
Speak soon
Ty
