Sashaj8
Just joined
Can't connect hub to Sony tv
I had Virgin Media super hub (vivid 100 optical fibre) broadband installed this morning. I have been able to connect mobile & pc but can't connect our Sony tv, through wireless connection. The tv finds the wireless connection but then says local access failed & internet access failed. I have tried both scan & wps options, also turned off & restarted everything.
I'm in area 31, if it helps!
Any help would be massively appreciated!
  • 4.31K
  • 91
  • 282
Moderator
Moderator
Re: Can't connect hub to Sony tv
Hi Sashaj8
Welcome to the community and apologies for the late reply. Are you still experiencing any problems connecting your Sony TV? If so can you try changing the wireless channel and see if this makes any difference with the connection attempt?
Speak soon,
Ty
