caggi1983
Message 1 of 8
Can't connect Kindle to wireless
I set up my Super Hub 3.0 a few days ago and connected wirelessly to my iPhone SE without any problems. However, I can't figure out how to do it with my son's Kindle. Going onto the wifi page, it isn't listed as an available network and I've tried to add it manually but when I save it, it says "out of range". I've turned the Kindle off and on again and I've pressed the WPS button on the Super Hub but it's still not even acknowledging that the network exists. Help please!!!
Helpful Answers
  • 347
  • 16
  • 69
wonkotsane
Fibre optic
Message 2 of 8
Re: Can't connect Kindle to wireless
It could be this problem: https://www.amazon.co.uk/forum/kindle/ref=cm_cd_et_md_pl?_encoding=UTF8&cdForum=Fx3IRFCNF3E5K2W&cdMs...
Do you know how to change this?
Massage an ego, click the kudos button. If someone answers your question, mark it as helpful.
Be nice, eat all your vegetables and keep your room tidy.
All Replies
  • 347
  • 16
  • 69
wonkotsane
Fibre optic
Message 2 of 8
caggi1983
Message 3 of 8
Wow, thank you so much! I'm very grateful for the swift response and the link you sent had all the answers I needed, thank you so much, we're up and running now!
  • 347
  • 16
  • 69
wonkotsane
Fibre optic
Message 4 of 8
Great news. There are a few really common devices out there that struggle with the Superhub (and other routers). Nintendo DS has a problem negotiating the 5G band and Chromecasts used to have the same problem too.
Peroni10
Message 5 of 8
Having the same problem. Kindle paper white.  Connected to wifi at Christmas when bought, and worked ok. Came back from holiday and it connected automatically - but today doesn't connect and have tried everything from rebooting both hub and kindle, reserving an IP address for kindle, renaming wifi u
  • 347
  • 16
  • 69
wonkotsane
Fibre optic
Message 6 of 8
Go into your router config and change the security from WPA (Auto) to WPA2 (Not Enterprise).
Peroni10
Message 7 of 8
Tried to WPA thing too, no luck.
  • 347
  • 16
  • 69
wonkotsane
Fibre optic
Message 8 of 8
That's fixed it in the past. Try setting up the guest network - that only uses the 2.4GHz channel which was the workaround for the Chromecast and Nintendo DS.
