  • 69
  • 5
ibbotson
Message 1 of 8
CCTV DVR to Super Hub
I am running my computers via wifi to Super Hub but I have just bought a CCTV System DVR which I need to setup via ethernet cable for network operating. Can I just plug cable into a port at rear of hub to setup DVR without affecting any wifi settings.
My CCTV DVR is non Wifi Floureon model.
  • 1.22K
  • 52
  • 172
jpeg1
Knows their stuff
Message 2 of 8
Re: CCTV DVR to Super Hub
Yes.
Note that if you want to access the DVR remotely you will need to set up port forwarding for the ports your DVR uses.
  • 69
  • 5
ibbotson
Message 3 of 8
Can I ask how to do port forwording via super hub. Sorry but this is not my error of knowledge.
  • 16.52K
  • 1.38K
  • 3.38K
Message 4 of 8
the ports you need to forward should be covered in the manual as for hub settings http://help.virginmedia.com/system/selfservice.controller?CMD=VIEW_ARTICLE&ARTICLE_ID=27625&CURRENT_... dont need to worry about port trigger
  • 27
mac2474
Message 5 of 8
If you know the correct ports your device needs to forward have a look at this:
It's not by me but may help you.
  • 69
  • 5
ibbotson
Message 6 of 8
Following on from advise given I have gone into my super hub to open port 80 for my CCTV DVR.
When entering the predefined rule for port 80 it inputs the default options for that rule.....but it shows an IP Address as follows 192.186.0.? and only gives the option to change the last digit (?) which I believe this has got to be changed to my DVR IP Address..... BUT my DVR has the IP Address 192.168.1,10 which means I can only change the ? to 10 but not the digit 1 to 0
Any help appreciated on this.
  • 1.22K
  • 52
  • 172
jpeg1
Knows their stuff
Message 7 of 8
Are you sure the DVR's address cannot be changed? That would be unusual. Go into its settings and try it.
RL161
Message 8 of 8
hi, was there ever an outcome on this as I have a swann cctv that I want to set up on my network and I cant seem to manage it
