  • 5
Dav83
Message 1 of 9
Broadband not working TiVo fine...?
Hello,
I have shortened my coax cables today and since reconnecting everything the broadband signal has not returned (flashing blue tick). TiVo has been working fine however and I even tried swapping the coax cables from the TiVo to the router to see if it was a wiring issue - it isn't, still no broadband. I have called virgin and the first engineer appointment is for next Friday (in 6 days...).
Here are the details from the network test:
Downstream AcquisitionLocked
Primary Frequency259000000 Hz
DHCPFailed
TFTPFailed
Time Of Day--:--:--
SecurityDisabled
Counters T1,T2,T3,T4,Sync,Resets000,000,001,000,000,000
Internet Connection IP Address Status
WAN IP Address---.---.---.---
Lease Time Remaining-- days --h:--m:--s
Expiry--- -- --- --:--
Current Network Time--- -- --- --:--
Downstream Channels Lock Status Channel ID Frequency Modulation Rx Power RxMER Pre RS Errors Post RS Errors
Locked16259000000 Hz256 QAM3.7 dBmV 36.8 dB275275
NotLocked  Unknown
NotLocked  Unknown
NotLocked  Unknown
NotLocked  Unknown
NotLocked  Unknown
NotLocked  Unknown
NotLocked  Unknown
To reset the Pre and Post RS error counts please use the Downstream screen under the router status screen available from the login page.
Upstream Channels Lock Status Channel ID Frequency Modulation Tx Power Mode Channel Bandwidth Symbol Rate
Locked324400000 HzATDMA51.8 dBmV64QAM6400000 Hz5120 Ksym/sec
NotLocked00 Hz 0 dBmV  0 Ksym/sec
Can anyone help please? Thank you
  • 16.71K
  • 1.4K
  • 3.43K
Message 2 of 9
Re: Broadband not working TiVo fine...?
How shorter did you make the cable, since the signals need to be correctly balanced and since you've cut the cable possible not done correctly can cause whole host of issues not not just.for yourself but others that share the same cabinet since you might have put noise Ingres into network, its possible the engineer might charge you for call out standard fee of £99
  • 5
Dav83
Message 3 of 9
Hey Paultechy, thanks for the reply, after leaving the router alone for four hours it started working again... it's a bit of a mistery, hopefully it will keep working
  • 16.71K
  • 1.4K
  • 3.43K
Message 4 of 9
could you repost the downstream, upstream to see if its affected
  • 5
Dav83
Message 5 of 9
Sure I'll repost when I'm back home cheers
  • 5
Dav83
Message 6 of 9
Here we go, thank for the help Paultechy:
Downstream Channels
Locked 40 323000000 Hz 256 QAM -0.4 dBmV 36.4 dB 1191 918
Locked 17 267000000 Hz 256 QAM 0.4 dBmV 37.1 dB 1568 285
Locked 18 275000000 Hz 256 QAM 0.1 dBmV 36.6 dB 971 930
Locked 19 283000000 Hz 256 QAM -0.2 dBmV 36.4 dB 324 285
Locked 20 291000000 Hz 256 QAM -0.2 dBmV 37.1 dB 919 919
Locked 37 299000000 Hz 256 QAM -0.4 dBmV 37.1 dB 318 302
Locked 38 307000000 Hz 256 QAM -0.4 dBmV 36.8 dB 948 946
Locked 39 315000000 Hz 256 QAM -0.1 dBmV 36.8 dB 307 306
Upstream Channels
Locked 2 31000000 Hz ATDMA 54.0 dBmV 64QAM 6400000 Hz 5120 Ksym/sec
NotLocked 0 0 Hz 0 dBmV 0 Ksym/sec
Locked 1 37600000 Hz ATDMA 54.0 dBmV 64QAM 6400000 Hz 5120 Ksym/sec
  • 16.71K
  • 1.4K
  • 3.43K
Message 7 of 9
your upstream power level is right on the upper limit, could you also paste the network log.
  • 5
Dav83
Message 8 of 9
Sorry for the late reply. Here is the network log:
Date Time Error Number Error Description
06/02/2017 21:40:27 GMT 66050310 Auth Success - Web login successful.
06/02/2017 21:40:07 GMT 66050310 Auth Success - Web login successful.
05/02/2017 10:12:38 GMT 66050310 Auth Success - Web login successful.
05/02/2017 00:07:14 GMT 66050310 Auth Success - Web login successful.
04/02/2017 17:36:56 GMT 68010302 DHCP WAN IP - removed
04/02/2017 17:35:52 GMT 68000407 TOD established
Time Not Established Time Not Established 84000510 Downstream Locked Successfully
04/02/2017 17:34:50 GMT 69011200 SW download Successful - Via Config file
04/02/2017 17:31:50 GMT 68010302 DHCP WAN IP - removed
04/02/2017 17:31:13 GMT 69010200 SW Download INIT - Via Config file tftp file-********
04/02/2017 17:31:05 GMT 68000407 TOD established
04/02/2017 17:30:52 GMT 82000200 No Ranging Response received - T3 time-out
04/02/2017 17:30:51 GMT 82000200 No Ranging Response received - T3 time-out
04/02/2017 17:30:45 GMT 84000510 Downstream Locked Successfully
04/02/2017 17:30:14 GMT 73000200 REG RSP not received
04/02/2017 17:30:14 GMT 73027100 T6 Timeout and retries exceeded
04/02/2017 17:30:14 GMT 73025103 Registration RSP rejected unspecified reason
04/02/2017 17:30:14 GMT 73025104 Registration RSP rejected message syntax error
04/02/2017 17:30:13 GMT 68000407 TOD established
04/02/2017 17:29:57 GMT 82000200
[MOD EDIT: Personal and private information has been removed from this post. Please do not post personal or private information in your public posts. Please review the Forum Guidelines]
  • 4.34K
  • 91
  • 282
Moderator
Moderator
Message 9 of 9
Hi Dav83
Thanks for posting. I'm unable to test your connection at the moment  as there is currently some work being carried out in your area (C00771541) which may cause an intermittent service. It's due to be completed by 5pm so if you are still experiencing any issues since altering the coaxial cable can you post back here after this time and we'll certainly look into it with you Smiley Happy
Kind regards,
Ty
