Mickod85
Broadband dropping, hub flashing green
My broadband has continually dropped for 2 days now & seems to flash green every 10-15 minutes or so.
All of my connections are so fine so I can't figure out why this is happening??
  • 3.67K
  • 87
  • 352
Stythinator
Problem sorter
Re: Broadband dropping, hub flashing green
Hi there,
I think a call to Customer Service on 0345 454 1111
They will be able to check your connection and see if there is any work being done in you're area etc.
Stythinator
If someone's helped you out say thanks by clicking on the Kudos Star. If someone's solved your problem, why not mark their message as an Accepted Solution.
  • 10.82K
  • 309
  • 632
HI Mickod85,
My apologies you are experiencing intermittent broadband connection. I can imagine how annoying this must be.
I've checked your connection, the line and hub have come back as fine, with no time-outs reported since the router has been online.
Are you able to post the network log from the router settings please? To do this type in 192.168.0.1 in the address bar, no need to sign in and click on Check router status. Within here you will have network log. You can copy and paste this information, that would be great.
You can also create a Broadband Quality Monitor which will check the performance of the connection. If you do set up a BQM you will need to disable the firewall within the router.
Let us know how you get on
Sam
