  • 6
nathanw97
Broadband Issues
i have a problem with the range from our rooter (Hub 3.0). I brought some tp-link power line adapters but only get around 12mbps. is there anyway i can get the speeds i am getting by the rooter (180mbps). thanks
  • 16.52K
  • 1.38K
  • 3.38K
Re: Broadband Issues
hiya @nathanw97 welcome to the virginmedia community forum, with the power lines the advertised speed is under there lab testing, e.g. 1 power cable in a straight small line. you could try and tweak the wireless on the hub via -> http://help.virginmedia.com/system/selfservice.controller?CMD=VIEW_ARTICLE&ARTICLE_ID=27539&CURRENT_...
