Ashen1
Just joined
Broadband Issue
My broadband unit hasn't been working since this morning. Every time I try to open the internet it comes up saying your unit is updating, this has been displayed for the past 7 hours. I tried calling customer support and after a lot of time trying to understand the foreign operator, he was useless so sort your **bleep** out virgin!!
  • 16.08K
  • 1.34K
  • 3.25K
Re: Broadband Issue
hiya @Ashen1 welcome to the virginmedia community forum, i would be doing a pin hole reset guide -> http://help.virginmedia.com/system/selfservice.controller?CMD=VIEW_ARTICLE&ARTICLE_ID=27643&CURRENT_... if this doesn't work if you can report back.
  • 3.88K
  • 120
  • 203
Forum Team (Retired) Adam_L
Re: Broadband Issue
Hi Ashen1,
Thanks for posting! Sorry to hear that your broadband hasn't been working, I apologise for any troubles.
I have tried to run some checks form here but I was unable to locate any of your details via your forum account, in order to get this sorted for you I will require some additional information from you.
I will send you a PM (Purple envelope at the top) detailing what's required to proceed with diagnostics, please respond to me there and I'll get this sorted for you.
Take care,
Adam.
