  • 22
danwellman
Message 1 of 18
Blocking websites using superhub 2
I've got one of the new superhub 2 routers. I want to block certain websites so that any user on any device accessing the internet through my connection will not be able to view these sites.
Direct domain blocking would be Ok as there are specific sites I want to block, but also regex based blocks, so that any sites with particular words in the title can also be blocked, would be great also.
Blocking is adequate, ideally I'd like to redirect also, so that the user is aware their efforts are actively being foiled Smiley Wink
Is this possible on the superhub 2 devices?
Tags (2)
Helpful Answers
  • 13.4K
  • 595
  • 1.64K
gary_dexter
Message 2 of 18
Re: Blocking websites using superhub 2
Unfortunately there isn't.
OpenDns on the devices is the best bet - has to be a PC or laptop though for the setup
All Replies
  • 13.4K
  • 595
  • 1.64K
gary_dexter
Message 2 of 18
  • 22
danwellman
Message 3 of 18
Ok, thanks. How about having a different router sat between the superhub and the rest of the devices? And configure it on that. Is that possible?
  • 13.4K
  • 595
  • 1.64K
gary_dexter
Message 4 of 18
You can put the SH into modem mode and use your own router yes - so long as the router you choose supports it in its firmware
i recommend the ASUS range of routers if you are in the market for a new one
  • 14.44K
  • 641
  • 1.46K
Moderator
Moderator
Message 5 of 18
Hi Danwellman,
Unfortunately the keyword and domain block are no longer features on the new superhub 2. They may be implemented in a later firmware but I'm not sure at present. Gary_dexters suggestion of OpenDNS is indeed your best bet with this one. Whether on PC or router.
  • 22
danwellman
Message 6 of 18
Ok great, thanks guys Smiley Happy
So, openDNS on the router, is this supported on superhub2? Is it easy to setup?
I think I did ask one time about openDNS on superhub 1 as I wanted to serve content from my home machine but at the time it wasn't supported, has that changed?
  • 14.44K
  • 641
  • 1.46K
Moderator
Moderator
Message 7 of 18
Hi Danwellman,
I'm afraid it isn't supported on either. There have been many requests for this feature to be added but at present we don't know whether it will be implemented.
Hope this helps
  • 13.4K
  • 595
  • 1.64K
gary_dexter
Message 8 of 18
You would need to get your own non-VM router and connect it to the SH in modem mode as the SH does not support changing of DNS
  • 22
danwellman
Message 9 of 18
Can anyone recommend a specific router known to work with Superhub in modem mode with comparable wifi speed/range and which supports openDNS?
  • 76
  • 7
  • 7
Treboul
Up to speed
Message 10 of 18
What's your budget can recommend the Asus RT-N66U but you may find the £100+ price tag a bit steep
